munk said:
Too soft? I'm learning something. Satori, I thought the steel had to be soft to come off as a spark?
munk
He ain't kidding Munk, for a fire steel (flint striker) to work when struck against a sharp piece of flint, or other stone in the quartz family (not a ferrocium rod on a magnesium fire starter), it must be non-alloyed, high carbon steel, with a rockwell hardness of around 62, preferably even higher (described by blacksmiths as "brittle hard").
None of the modern chakmas I've tested so far passed muster, but as Dave mentioned, some of the "old school" antique chakmas from AC work as they were originally intended. Old files are plentiful
I simply heat up the blade on my "as issued" chakma until the laha softens enough I can pull the blade free with vice grip pliers. Then, it's a simple matter of grinding a matching blade from an old file and re-inserting it into the original handle. Done right, you'd have to look closely to spot any signs of "tinkering".
As far as Kevin's original question, yes, if you use one edge of a suitably hard chakma exclusively as your fire starter, and the other edge exclusively as a burnisher, it can quite happily live with the "double duty".
Sarge
