Kydex adjustment
I just got a groovy litle neck Fang and have a question about the sheath. The fit is too tight; it hurts my neck to pull it out and is showing wear on the black-T finish. How do I enlarge it? Is it just a question of heating it up?
Thanks for any feedback
Kallisti
In my opinion, the best way of doing limited and controlled heating for minor adjustments without the whole thing turning into a "wet noodle" is to heat the area of kydex you want to adjust in the steam coming out of a boiling teakettle spout.
In this case, you probably want to heat JUST the opening area to the sheath. Wear leather gloves, heat just that area in the steam blast and then insert/extract the knife a few times. If it gets too loose, heat it again and then squeeze it tighter with the gloves on...so long as you keep your fingers out of the actual steam path you should be OK.
The Kydex will NOT turn "totally limp", but you will be able to make it move with a bit of force and it'll then take that set. You're *barely* heating the Kydex to a point where it'll permanently change shape, so expect it to cool FAST as hell, which is fine. If you have to make several small adjustments, no sweat.
Once it looks OK, dry the knife really well and then hang the sheath to dry with no knife in it. There'll be a ton of moisture still in there, let it dry before re-sheathing...this is what you'd do after an outdoor session with rain, for example. Do this even if the blade is ATS34 - that steel is "not EXTREMELY stainless" (if that makes sense), it's a "borderline stainless/tool steel".
Jim March
Equal Rights for CCW Home Page
http://www.ninehundred.com/~equalccw
OK - I did as you suggested. The sheath is now of a more reasonable fit. It's looser at the collar, as desired - but also, there seems to be more play further up where it shouldn't have gotten even warm. It doesn't bother me though. I may do more surgery later to get a more totally precise fit, but I got the result I wanted for now
I am no longer shy of playing with kydex!
Thanx again -
Kallisti
[This message has been edited by Kallisti (edited 14 August 1999).]
Interesting yours was too tight...mine has excellent retention, but there is quite a bit of play and rattle toward the tip. You can use a heat gun and sometimes a hair dryer, too, but it is a little tougher to control and is easy to burn the material.
My Custom Kydex Sheath pagehttp://www.geocities.com/CollegePark/Lab/1298/knifehome.html
Palmer College of Chiropractic
On Two Wheels
