I've never used Admiral's steel, but have used Crucible's L-6, and I can tell you it's a pain to anneal. I finaly got it soft by triple normalizing and then for the annealing cycles I took it to just below criticle three times letting it cool down in wood ash between two plates heated to non-magnetic. I don't have a oven to bring it down slow like it's suposed to be done. The chrome in L-6 makes it air harden somewhat.
I've mixed it with 52100, 5160, 1084, 0-1, and 1095, and the best mix I came up with was 0-1 and L-6, but the 1095 wasn't bad eigther. Basicly weld it up, get the layer count you want, and triple normalize, and triple aneal. Then heat to non-magnetic and quench in oil heated to 135-160 depending on the type of oil you use, the faster the oil, the lower the oil temp.
temper at 350f. for two hours, flex the edge, if it chips raise temper temp 25 degrees till it quits chipping out.
Hope this helps.
