- Jan 29, 2003
The HWK+ (bottom) with the original HWK (top).
Background
Here is a link to information on the original: Ray Laconico HWK
I could not have been more pleased with how the original Laconico HWK (Hazard Woods Knife) turned out. It is proving to be a great all-round tool that I am more than proud to have my name on. In fact, it went so well that I immediately thought it would make a great larger knife as well.
HWK+ Stats:
3/16" thick O1 steel
Ray's typical tall flat grinds with polished convex edge
5" blade
10" overall
Green G-10 handle slabs
The HWK+ with Victorinox Farmer and Original HWK for scale.
Getting it Dirty
I removed the HWK+ from the package and, as is my custom, began to cut up the wrapping materials that it came in to test the edge. This knife came from Ray shaving sharp, as usual. There is something satisfying about a knife that can easily push cut the newsprint in which it was packed!
The HWK+ has a thick spine and nicely contoured handle.
The HWK+ has a phenomenal handle. It is very hand filling and has excellent contours. It promotes a very secure grip without forcing the hand into any one grip. The green G-10 handle material has a very cool translucent quality to it that makes this knife very attractive.
The blade shape is designed for versatility, just like its smaller sibling. There is plenty of belly, a large section of straight edge close to the grip for cuts that need leverage, and a point that is dropped to be inline with the handle for drilling. Ray does a great job of creating a tip that is fine enough to cut very well without being prone to breakage.
Fine curls are no problem for HWK+ in spite of its thickness.
The next test for the knife was some fire prep. Shaving "feather sticks" can be a test of a knife's sharpness and edge geometry. Even though the HWK+ is 3/16" thick at the spine, Ray's use of tall flat grinds yield excellent edge geometry. The HWK+ is capable of very fine curls.
Deep, precise notching? No problem!
Another test of geometry is how well a knife performs at notching. This is a difficult task for thick knives but the HWK+ holds its own. It simply can't bite as deep as thinner knives. However, by using a stop cut and then working the notch deeper one slice at a time, you can achieve very precise notches.
The HWK+ has all of the makings of a versatile and dependable woods companion. It would be at home on the belt of anyone who loves time spent in the outdoors whether they are a hunter or a hiker. The HWK+ would even make a fine knife for a soldier.
Matt Hazard
