Originally posted by Laredo7mm
I ground out the slots with a cutoff wheel mounted to my grinder drive shaft. Dangerous, but effective.![]()
Originally posted by NickWheeler
I was thinking I showed you the blade here that I cut the ladder into after forging the preform for the blade...?
I like the effect you get with that method. Forge the point down and get the cutting edge flat on the anvil (just like I start all of my blades) and then cut the ladder groves in. When you forge the bevels in it smooths everything out and keeps the pattern in without worry of grinding it out.
When I get that motor set-up with the double cut-off wheels it will work very well for grinding the ladder grooves in whether into a rectangular billet or a blade.
Nick
