Well I can tell you about the one I have, it's a Laguiole de l'Artisan 10cm folder in 12c27 SS and a dark horn handle.
I bought it about three years ago because I liked the history behind the style and because they have a handmade look, I think I paid around $70.00 back then.
The appearance is very nice , it has a high polished blade that was shaving sharp out of the box, and the fit and finish is very good. I like the cross that's made with rivets in the handle, it's a nice touch, along with the filework on the backspring. It has the strongest spring I've ever felt in a slip-joint and when open it almost feels like the blade is locked.
When I first got it I was pretty impressed by the old world craftsmanship , but mine has a flaw that might be inherent with the design. About 1/4" (or less) of the blade strikes the back (inside) of the frame when closing and these have a pretty strong spring. After awhile a small section of the blade is getting deformed. I understand the French use something to cushion the blade, but it's not a good aspect of the design. I don't know if they are all like this , but I've read others complain about it
Cornelis Böhms;4075643 said:Only Fontenille Pataud has a blade stop on their lock back laguioles.
All other laguioles are to be gently closed and never with a 'snap'.
The French dont use anything to cushion the edge.
For the experts![]()
Witch manufacturer has your preference?
Laguiole en Aubrac
Fontenille Pataud
Forge de Laguiole
Laguiole de lartisan
I there a great difference in quality between these four?
Witch on has the best quality vs price?
Thank you
I have one from Laguiole de l’artisan, it is the 12cm Prestige model with corkscrew and Zebu horn tip bolsters. If I understand things correctly they are the last shop where each knife is made by the same individual from start to finish, or at least it was so about five years ago when I got mine.
As far as fit and finish go, I have never seen better and I have been quite happy with the Sandvik steel as it takes and holds an edge very well.
Cornelis Böhms;4075643 said:laguioles are to be gently closed and never with a 'snap'.
laguiole " le fidèle" also has a feature to prevent the edge to strike the back.
I have a de l'artisan with stainless bolsters and ebony handles and my wife got one with olive wood handles and brass bolsters.
Ron
