Jeff Clark said:What I really want is a blade that has a tool steel core hardened to 64 and simple carbon steel on the outside hardened to 56. You don't tend to find that combination in laminated knives. I'm not sure how compatible the heat treatments would be to get that arrangement.
HoB said:I would think that if there were any major drawbacks to it the Japanese would have given up on doing it after a while ...
Richard Sommer said:Is there any downside to knives made with laminated steel blades? I understand the merits, harder core for holding and edge and softer sides for toughness, but is there any reason to avoid such knives? Thanks.
dannyv said:I suppose the soft side means 50 as opposed to 65 for the hardness of the core.
misque said:The outer skin around the hard layer is much more prone to scratches than a fully hardened blade.
DGG said:I think this is referred to as "San-Mai". I found a reference to it on the Cold Steel website.
QUOTE]
Actually, the japanese term is "warikomi" when the hagane (core) is surrounded on both sides by Jigane (outer layer). If the Jigane is welded only to one side of the Hagane it is called "kasumi". Cold steel invented the term "san-mai" for their own laminated blades.
