laminated steel blade WIP
HSC ///
good day all, I made this little documentary for another forum but thought I would post here for your enjoyment,
I worked on a blade yesterday and thought I would take a few pics for a little WIP.
steel bar is laminated Hitachi white with stainless cladding.
What the flat bar looks like and after a few heats of forging/shaping and drawing out.
more or less final forging with taper from tang to tip, precision forging isn't necessary. The blade goes into wood ash and vermiculite for annealing. Then it's easy to saw and grind the profile as required
cold forged, profiled, straightened, stamped, tang shoulders cut
check to make sure the core is centered
with clay slip layer ready for HT and quench
quench into straight water
quenched and flash tempered
straightened blade on wood stump after hardening
initial rough grinding and check to make sure the core is exposed properly
more straightening as required during the grinding process
and that's it...blade is ready for final grits and polishing
thanks for looking, any questions?
Harbeer
From that picture final forged to the next one was that all cold forging smoothing out the surface and is the purpose of cold forging to make up for the different rates of expansion of the two metals and to relieve some stress before heat treating. Also is the cold forging on the outer layers only and not profiling looking good thanks
yes, smoothing out the highs and lows, the surface smoothing is more noticeable with a 50 lb power hammer than it is by hand.
The purpose is primarily smoothing of the outer layer surface, blending the highs/lows. I don't thing stress relieving is accomplished by cold forging.
yes cold forging is on the outer layers only.
