I've only used epoxy to laminate G10. I laminated some sheets together in the past, once. This was 4 layers;
I haven't laminated sheets since then, just handle sized pieces. If and when I do it again I'll avoid the screwups I made last time. This knife and a couple others I made from the material had a few air pockets open up between layers, super tiny and not a structural issue but annoying and time consuming to take care of. Also, my sheets slid apart a bit so I didn't get as much material as I could have.
1. coat every surface that will touch another with a very thin layer and make sure there are no voids
2. wiggle the pieces against each other to make sure the epoxy is consistent between layers
3. tape or otherwise hold the pieces in place so they don't slide around
I put my granite slab on top to distribute the weight equally across the sheets. Waxed paper top and bottom to keep the epoxy from getting all over the place. I put a few more things atop the granite slab, I think maybe put a bench grinder on there too- maybe 65-70 pounds of weight. It was all done on a finished concrete floor, but I think I should have put down something else first that I knew would be flatter than the floor
