I have been sharpening with a Lansky for quite some time and have been disappointed with some of the results, namely edge durability. Getting a nasty sharp edge has never been a problem but the durability of the edges just didn’t seem right for the angle I was setting. On a whim I decided to verify the Lansky’s slot angles with a protractor. Low and behold I found that measuring the clamp alone was shallower by about 2-3 degrees than is marked on the slots. This got me to thinking that if the angles are shallow just to the end of the clamp how shallow are they when the width of a blade is added.
The Lansky is a triangle system and a little triangle math tells us that as you extend the length of one side of a triangle the angles are reduced on that side. My math skills are pretty rusty but I did the measurements of the height of the slots and the length of the base when a blade is clamped in and the math showed that adding a 1-1/4” blade will yield the following angles on the edge:
17 degree slot = 10.9 degrees
20 degree slot = 14.4 degrees
25 degree slot = 17.8 degrees
30 degree slot = 21 degrees
Has anybody else done the math on the angles created on their Lansky system on various blade widths?
If my math is hosed I’d appreciate somebody setting me straight. I’m not blasting the Lansky as it works pretty well in maintaining constant angles. However, if my measurements and math are right it would sure help explain why edges aren’t holding up quite as expected because the angle was significantly less than I thought it was.
I’d appreciate it if one of you more mathematically inclined folks would grab your Lansky, do a little measuring and calculating, and let me know if I’m off my rocker.
LON
LON
