It's very easy with the Lansky system, but not always fast, just take your time with it.
If you need to change the profile of the edge, start with the course, see how well this is removing material. If it's not really doing the business, go to the extra course, then work your way through the grades. Each finer stone needs to remove the scratches of the previous one, and you want to remove the minimum material necessary, sometimes you wont need to start with extra course.
Just make especially sure that the guide rods are parallel and in line with each stone, use a flat surface and don't be afraid to tweak the guide rod by bending it slightly as required.
Once you have re profiled the edge, it will be much easier and quicker next time as the edge will correspond to the angle on the lansky and you can start with a medium of even the fine stone as you wont need to remove very much material.
