Oh the lansky. It's still what I use primarily. First off, I will always reprofile my blades to the lowest angle I can. Ideally all the way to the apex, but anymore I don't worry too much about getting the edge super sharp at this point. After reprofiling it will make it much eaiser to hit the apex when moving up to a higher angle to form the micro bevel.
I'm not sure what you already know, but let me back up a little bit:
1. Before you use one of the hones lay it stoneside down on a flat surface and loosen the metal rod completely and tighten it as it sits. If the rod is not completely flat, I bend it either up or down and loosen it again and tighten it again until everything is laying flat. If you do this for each hone it will result is a much more consistent angle of sharpening.
2. While sharpening I always hold the clamp with my finger behind the slot pushing lightly upwards on the rod that is coming through this way the rod is tight against the top of slot and again sharpens at that same consistent angle (tip it helps to put a cloth or paper towel in between your finger and the rod)
3. I personally sharpen with the hones up and down along the whole edge until a burr starts to form and then I do several sweeping strokes along the whole length of the blade. Then I will form a burr from the other side the same way .. Then I start do say 30 sweeping strokes on one side and then the other... And keep going back and forth with less stokes each time.. With practice you can start to feel how many strokes a side needs when the stone just starts to feel fluid and glide across the blade... This step is the most important for the last hone, but should be done for each.
4. The last hone or last couple .. To make sure that the finest hone is absolutely hitting the entire apex you can tighten you lansky clamp a little before you start on the last hone... Or unclamp and move your blade further back in the clamp just a tiny bit. Then I do the sweeping strokes on each side.. Starting with a lot on one side then getting less and less until it feels super slick on both sides ....then I strop a little bit and it is usually good to go! Shaving sharp ... Sure I forgot something, but I hope that helps. Don't hesitate to ask questions.
Edit : I will blame the typos on mobile spellcheck... But beers could be a factor also.
