Keep in mind, the 'spec' angles as marked on the Lansky clamp (or Gatco, or DMT, or etc.) won't likely be accurate anyway. I recently starting taking some measurements of blade-in-clamp, and using trig functions to calculate actual angle. One thing that surprised me, the marked angles on the Lansky clamp are based on the hypothetical 'edge' of the blade being flush to the front of the clamp. If the blade extends even slightly beyond that (as it must, in order to actually reach it with the hones), the actual angle will be less than what is marked. I've been using my Lansky on several traditional pocketknives lately. Most of the blades are ~ 1/2" - 5/8" wide, and I use the small notch in the end of the clamp to hold these blades. That means my edges are roughly ~ 3/8" or so beyond the clamp's front edge. As it turns out, the actual angle produced on these blades, when using the '17' setting (lowest), is closer to 15 degrees per side, or slightly less. The same generally holds true with the clamp's other settings. With blades that are very wide at all (3/4" up to something like a large chef's knife or meat cleaver at 2-1/2" or more), the actual angle will be much, much lower than indicated by the clamp's markings.
So, long story short, if you really are concerned about hitting a specific angle measurement, you'll need to measure and/or calculate for it. Relying solely on the clamp's marked settings will lead you astray.
