If your stones are loaded with metal, they are not cutting, and then you are sneaking up on a bur, but never obtaining a bur. As your stones move across the edge towards the spine, the edge will fold and curl to the opposite side. Once a bur is achieved, you can take the blade rake it across your finger nail or thumb nail on the bur (opposite side you are sharpening) and it will peel or shave some of your nail off. You can also use the tip of your fingernail and scratch at the opposite bur edge to see if you feel a ridge. It will be there. Once you have gotten the bur, and not until there is one, do you repeat on the opposite side and then move to the next finer stone. You will get it. Remember to clean your stones, Bar Keeper's Friend. Clean stones cut nice and fast. Make sure your angles stay constant. Once you have reprofiled your bevels with the coarse stone, the bur raises quickly with each finer stone. 85% of the time is spent with the coarse stone to get it reprofiled at your desired angle. I use the 22 on the Lansky. Once you have achieved the reprofiled angle being tested by the bur, and moved through all of your stones, take your honing stone, the finest and set it one or two angles steeper, say 30 degrees and set a micro bevel. This will be with very easy pressure, not hard. This makes your blade geometry that of a razor blade. I first did this with my Lansky and then could get hairs jumping. I got so happy, the back of my hands were bald! Keep it up, do not give up, get a good magnifying glass or jewelers lens. Keep obsessing about it, it is healthy. Good luck Mr. Edgy!
