- Aug 10, 2012
I want to start off by saying I'm 15 years old, so some of these sharpening tips and tricks will be a little tricky for me to understand at first, but I'm willing to learn and I appreciate anybody that's willing to take the time to help me.
I recently received a Deluxe Lansky Sharpening System from a very good friend on here (Thanks again!). I've been able to sharpen my knives (all Kershaws) and produce a pretty good edge, but nothing razor sharp. I'm happy with the results, but I want to be able to get to that next level of sharpness. The steels that I've been sharpening are 8Cr13MoV and 14C28N. I've been using the C-Clamp and just setting it up on the corner of a table (being careful not to ruin the table or over-torque the clamp). I've got it as parallel with the table as I can, which is pretty parallel. I also have the clamp that you use to place the knife blade in and I've put tape on it where you clamp it down to the knife so it doesn't leave any scratches. I'm also careful to make sure that the amount of gaps between the rods and the stones when setting them up is very minimal. I've even labeled the rods to make sure I put them on the right stones, because for some reason, there will be gaps with some stones than with others. I also made sure to use the straightest rods I have for consistency. Also, I ALWAYS Sharpie the edge so I know where I'm hitting with the stones. That's pretty much my whole set-up.
Now with the actual sharpening. So far, I've been starting with the 70 grit stone and moving on upwards because I want to get a good feel for how well the stones work. I know I probably shouldn't do that with a fairly sharp knife (I try not to let my knives get dull), but I just want to get a good feel. The knives I'm working on sharpening are an OD-2 (8Cr), Cryo (8Cr), and a Skyline (14C). Kershaw says they sharpen their knives anywhere from 18-22 degrees (non-inclusive), but I'm not finding that to be accurate. I'm finding them to be around 25-30 degrees, or that could just be my knives. I know the Lansky has some variation with the angles because of where you tighten the clamp on the blade and because of how the rods move around in the holes, but I think I'm fairly accurate with my assumption. Either way, I've just been sharpening them at the angles I've been finding them to be at. Since finding that out, I've re-profiled my Skyline to about 20 degrees non-inclusive, or at least that's what I've think I've done. It was previously at 30 degrees, and I Sharpied the edge and after awhile, the Sharpie started to go away at the edge, instead of at the shoulder. I continued to sharpen with each stone until I felt satisfied that I did a good job (I started at the 70 grit and continued upwards, with doing the re-profiling with the 70 grit). From what you've guys have read, do you think I actually re-profiled the edge? I continued to sharpen with the 70 grit until all of the Sharpie was gone, so I think I re-profiled it.
Ok, my head is starting to hurt from all of this thinking and making sure what I said made sense to you guys, so I think I'll leave it at that for now on. I have more questions, but I can't think of some of them right now. I'll ask those later on. Thanks for any help!
