Assuming a guided system is the priority:
For medium-sized fixed blades, you might consider a DMT Aligner clamp, but used with a bench hone instead of the full Aligner kit. Depending on the steels you're using, that bench hone might be something like a DMT (diamond) for more wear-resistant steels like S30V, D2, ZDP-189, etc. OR, if the steels are simpler, something like one of Norton's offerings should work well. Their 'Crystolon' stone in silicon carbide is popular for heavier grinding and bevel-setting, and their 'India' in aluminum oxide is well-regarded as a maintenance and finishing stone. For your budget, I'd bet you could accomplish a lot with the clamp (~ $10-$15) and the Norton Crystolon (likely can be had for < $30 in most places).
I suggest a bench stone, because the small Lansky hones will work pretty slowly on large and/or thick blades. Especially for setting a new bevel, a lot of steel needs to be removed, and a the very small Lansky hones will be slow for this.
I'm not knocking the Lansky. I have two of their kits (the 5-stone Deluxe kit you've mentioned, and a diamond kit), and they're especially good with smaller knives like traditional pocketknives. But even in simpler steels, these hones take a very long time to set a new bevel on thick/heavy/big blades.
David
