Danny Linguini
- May 24, 2022
A few months ago, I picked up a Lansky Diamond Sharpening System. It works ok, but, as I was concerned about, it’s limited by its four preselected edge angles. Most knives in reality usually fall somewhere in between those angles, meaning you have to do a lot of coarse shaping before you’re sharpening the whole edge. And worse than that, the clamp is clunky - yes, it has a clunky clamp - where on certain wider blade shapes the tightening knob gets in the way, and you can’t get to the 20° or 17° rod holes. I generally had a hard time clamping any blade tight enough so it doesn’t move, and I put about zero pressure on the sharpening rods. So I was less than thrilled with it, and set out to find a better replacement. While pricing out the Spyderco Sharpmaker, I stumbled across the Lansky Diamond/Ceramic Turn Box. It does basically the same thing as the Sharpmaker at a fraction of the cost, with a much simpler base/storage box, and it gets very good reviews. Only two sets of rods - medium diamond and fine ceramic - but I very, very seldom have needed anything coarser than medium anyway (except when a certain other sharpening system requires it because it can’t match the factory edge). So I grabbed one.
After just a few uses, I’m very happy with it, finding it much more comfortable and confident than the fancier Lansky system. Most of the time a few stokes down the ceramic rods and a quick stropping have been enough to get a paper-shaving edge back. And it’s very easy to adjust your grip to be able to follow any factory edge angle. I know there are better solutions out there, but I’m generally very easy on my knives, and they seldom need more than a touch-up, so the Turn Box seems to be a good choice for me. Just throwing this out there for others like me who want something inexpensive, but aren’t quite good enough to totally free-hand it - it’s a decent little sharpening set.
