- Mar 7, 2003
I just cut out a blade from a 14" lapidary saw blade. As far as I can tell it is either L6 or 1050. I can't eem to get any specific info. It has a slight bluish-gray cast in daylight when sanded and buffed with a scotch brite belt. It is about 1/16" thick.
I cut a 3 1/2" slice off of one side and will have 10 1/4" OAL with a 5" blade. The edge is the original blade arc and I ground the edge bevel from the diamond insert band on the edge. I can always grind it off later. It took 2 80 grit cibitron (977)belts to get the bevel on it.
I'm not sure what I will call it-skinner or psuedo ulu?
Anyway it seems like a fun experiment. I am going to try hardening at 1500, oil quench and dry ice with triple 400F tempers and see what happens. It should at least make a vegetable slicer.
I got several saw blades for free.
