Lapidiary work
Any recomendations on sanding/polishing semi-precious stones? I was thinking of polishind raw jade. Tried sanding it with my regular sander with a wood sanding belt. Guess what, ruined the belt. Thought that would happen, but didn't have anything else at the time. Anyways, what do you folks recommend?
Thanks
Ken M,
I remembered seeing something about gem cutting belts in my Tru-Grit catalog. I checked and they recommend the Klingspor CS-321. It is a silicon carbide belt and it appears to be available in several different sizes. I have never personally used them. However, it should give you somewhere to look. They can be found on the web at www.trugrit.com.
None are more hopelessly enslaved than those who falsely believe they are free. -Goethe
i use a "turbine" diamond wheel for roughing the jade down then silicon carbide belts on an expandable drum to 600 grit flooded with water.
finish polish wit 8000 diamond compound on a plain canvas belt.
Whew Thanks guys, I called Tru-Grit and they are sending me a catalog. They too mentioned about using Sillicone Carbide Belts or stones. We'll see when I get the catalog in. I think this will be more work than I thought. Gives me something constructive to work on now though. I think I may have to get more equipment also. Whew!
Once again, thanks! I got more direction now.
Ken
