- Jan 1, 2018
Wet/Dry, diamond hones, flattening stones or loose silicon carbide grit on glass- Ive got wet/dry sandpaper for lapping, but i probably wont use it too often again after hard-to-see particles putting furrows in my 4k/8k waterstone. Glass does work best as a backing for sandpaper but besides the particles between glass and abrasive you also may need to give some attention to where the abrasives wear away as well. So I had a thought and pulled the sandpaper out and just used the glass-topped table and water.
The loose grit works the way loose carbide grit would but slower so i started and would pull the stone up from time to time to see where it was flat and where not, and used my smallish diamond hone to wear away the spots that needed it most and speed things up.
No worrying about torn abrasive paper or gouging furrows... i dont pay too much attn to how i slide the stone on the glass until its nearly done, then i start rotating it clockwise & counter-clockwise to see where it has resistance. If there is resistance i keep up that pattern until it is smooth.
When the stone was smooth i used the coarser 4k side to put some loose grit back on the glass for the black arkansas stone, and repeated with 8k grit on glass. And for this too, i keep the diamond hone around to speed up flattening: when the stone is pulled off the glass gravity and suction pull the grit away from the low spots and the face of the arkansas stone looks like a topographical map, the spots with loose grit stuck to it get lapped with the diamond hone a couple of times, back on the glass to smooth it out, check progress and continue as needed. I believe it took me 60 minut
I know the sandpaper is probably faster but the more variables i have to deal with the more my back seems to ache as i work
