Pinoy Knife said:
who was it that was hunting racoon's with a bowie ? i remember them talking about hitting Concrete with no damage !
Hehehe!
I suppose it's nice that someone actually remembers, once in a while. Although I don't think I said
no damage; my new knife is certainly better at taking abuse than my older ones. I still have to sharpen out small nicks, but I don't have near as much trouble with chipping, and this one hasn't actually broken yet! I believe there is still a bit of room for improvement though, according to my research...
I'll share some of my philosophies, but they may contradict the experiences of others, so take this for what it's worth.
For something this big, I have no use for stainless steel. I am after strength and impact resistance. I do not worry about wear resistance, because I've never had one of my big blades get dull through abrasive wear. I have to sharpen out nicks and other damage long before they ever get "dull". I used 5160 for my current blade, but if I knew then what I know now, I'd go with L6, CPM-3V, or one of the shock steels. (S5 or S7) Kevin Cashen has done some initial testing in his new lab, and his results seem to concur with industry literature. L6 can take almost double the impact forces of several other common knife steels. Take a look at
this chart from Crucible, and you can google several others like it. According to people who know their steel, CPM-3V should have almost double the impact resistance of A2,
and double the wear resistance. S7 has
3 or 4 times the impact resistance of several other knife steels we're used to.
I'm planning to use one of these steels for my next knife, and see if I can get better edge durability. If soft targets were all I ever had to cut, I'd still be using that big Pakistani POS I started out with. I had to make better tools to withstand the accidental, but inevitable, strikes against steel, concrete, teeth, etc.
My current blade is full flat ground, and 2 1/4 inches wide. (~5.7 cm) So, it does get thin at the edge. Before sharpening, I left the edge about as thick as a dime. (about 1.1 mm or so) I found out the hard way, that any thinner won't be stong enough to prevent ripples on botched cuts. Considering your pole arm would develop even more power in a swing, it would probably be a good idea to do a convex grind if it will work with your design.
