Presuming you aim at hand-splitting logs into pieces which will dry so they are usable in fireplace or woodstove? I still split (mostly by hand but increasingly with help of neighbor's hydraulic wood splitter as I get older) & burn a lot of wood. Have about 5 cords ready for this coming winter. I'm just a "plugger", not an "expert" but here's my advice: Buy domestic, don't spend money buying "designer" foreign axes. You won't notice any better performance in a "hand-forged Swedish" tool for simply cuttting/splitting firewood. My favorite axe is stamped "Craftsman"; came from Sears. Had it for 40+ years. Replaced the handle a few times; still cuts well. Try to avoid the Chinese-made tools that are flooding U.S.; questionable steel, terrible handles. Don't try to find a single, all-purpose "splitting axe" design; won't do a decent job trimming off limbs or cutting trees to length as well as splitting. If you want to trim/chop logs with an axe (a lot of work if you use large diameter hardwood; chainsaw makes life a lot easier), get a full-size (3.5 lb. head), U.S.-made, polled, single-bit axe for that purpose at your local hardware store. If you beat it up badly, buy another. If you want to split logs, buy a heavy-weight splitting maul (again, domestic-made) at your local hardware, preferably one with a fiberglass handle. Maul splitting tends to beat up handles and fiberglass lasts longer than hickory handles. If you get serious about splitting or want to tackle the knotty logs that won't split easily with simply maul blows, buy a couple (at least 2) steel splitting wedges; again, simple domestic designs work fine...you don't need the fancy spiral-design or four-bladed ones. I've tried these and they end up getting stuck and have to be freed with the plain-jane wedges. A 3 lb hand maul is a nice addition to use with wedges, allowing one-handed blows with the other hand holding the wedge in place. One last piece of advice: use safety goggles when chopping/splitting. Wood chips fly and also an occasional steel splinter when using wedges.
