Larger p-b washers from CKK.....
ARtsig1
Banned
Just got a pak of these in today. They are the larger sized phospher bronze washers. The new ones are .500 X .197 (OD and ID) and thickness is .02. The ones I had been using were .330 X .197, with same thickness. Just replaced those on my Cuda MAXX with the larger ones and it works great.....actually had to keep the lockside washer I already had on it as the lock would not engage with the larger washer. Still works like a champ though and absolutely lines that blade up right down the middle upon closing.
I found that a Dremel with the polishing wheel on it will bring the washers to a high miror finish and then the addition of some Miltec 1 just finishes it off for a super smooth opening and NO blade wiggle.
check them out at www.classicknifekits.com
