jdm61
itinerant metal pounder
- Aug 12, 2005
I know that industrial salt bath setups can be quite large. I have seen a video of the high temp setup that Estwing uses and it is pretty big. Most of the "home versions" that I see use a 4 or so inch tube which pretty much means you can only HT long skinny objects. You run into the same issue with some of the knife HT ovens like my 24 inch Paragon unless you go up to the doublewide versions. Is were a way to do a larger salt or even sand pot, say wide enough to HT a one piece tactical hawk? Could you do an oval shaped tube?
