Laser thingy
Someone made a laser device for measuring blade angles. It is on one of those sites where new products are sold. The object is to get accurate before/after sharpening measurements.
Does this sound practical, or gimmicky?
Search 'laser goniometer' on the web.
These devices have been around a while, and some are pretty sophisticated & PRICEY. As for perfect & precise accuracy, I think they're still somewhat limited. But organizations like CATRA rely upon them for some pretty sophisticated testing of edge geometry vs. edge retention and sharpness.
Due to price of the good ones, maybe not 'practical' for hobbyists. But definitely not 'gimmicky', in that they can be useful instruments in knowledgeable hands.
Thanks Obsessed. Just thought I would ask because the cost of the one I saw does not seem too expensive, search Laser Knife Edge Reader. Maybe it is overkill since sharpening systems already set angles.
abcdef: Someone Ken Leonard made a laser device for measuring blade angles. It is on one of those sites where new products are sold kickstarter laser-knife-edge-reader-for-better-knife-sharpening . The object is to get accurate LASER before/after sharpening measurements.
Hi,
Its both :) the gimmick is you can take a picture of lasers and share with your customers
cutting doesn't require lasers, sharpening doesn't require lasers , edge angle measurement doesn't either
;) also laser pointer costs ~one dollar shipped, why pay 40 to 100+ times more?
Making Your Own Goniometer: How To?
I use a CATRA Hobbigoni blade edge protractor:
http://www.catra.org.uk/CATRA_Hobbigoni_blade_edge_protractor_p/cuhg.htm
It works pretty well, but can be difficult to use, especially if you're dealing with a coarsely ground edge, which scatters light. In addition, convex edges don't give an angle (convex edges do not have angles), but rather a reflection of all possible angles along the edge -- basically a range of angles measured at each point on the edge.
It does seem that a homemade device like the one above should work, as long as you get everything perfectly in line.
