the higher the grind goes toward the spine, the easier the knife will cut and slice. i see some discolored spots along the edge, dip the blade in water more often so the temper wont get ruined. if it turns blue it has gone soft.
Can you do the foil wrap on a knife sent to heat treat with any type of steel to prevent (if it will) the black build up? Or is that meant for only stainless steel?
I'm a noob too, but personally I like the look of your upper O-1 and the 154CM blades the best. I think it is because you have ground higher bevels on those ones.
