- Mar 13, 2006
Every couple of months I pull my lawn mower blade off and run it across the belt sander. Would there be any benifit to actually making it sharp? or would it just be gone too fast and or weaken it too much?
Ive put a good edge on my lawn mower blades and its gone after one cutting. There are many who say the best thing to do is put a small 1/16 flat 90 degree bevel on the edge. The idea is the 90 degree corner is enough to do the cutting on a lawn mower blade and it will last longer than the ground to an edge bevel. Ive done it and it does cut, not sure it lasts any longer though.
I found that it's $100.00 to replace the mandrel bearings ....Balancing will increase the life of your mandrel bearings for sure.
Well Possum make fun and criticize my post all you want.
It does work and cuts the grass just as well as a chisel sharpened blade.
And yes a round corner doesn’t cut but a nice sharp 90 degree corner does and it cuts very well on a lawn mower. It is also very easy to touch up with a file and I get much less chipping compared to before.
You ever hear of Gator Blades? They are a high-end blade and guess how they come sharpened?
Btw how wide is your 40 to 60 degree secondary edge?
Yeah sure thing dude.Calm yourself, dude.
A sharp 90 degree edge doesn’t have any problem cutting paper. In fact I’m not sure of the angle but I think paper cutters are pretty darn close to 90 degrees. But yeah try it on your blade and see if it works for you or not if you want. Even if you don’t it makes no difference to me.It may cut as well as a dull chisel sharpened blade. I don't see any way it could cut like a blade that can easily slice paper. But tell ya what.
In the spirit of fairness and learning, next time my blades get a little dull I'll swipe a flat on the edges and see if I can tell the difference.
Huh? I said a very small 1/16 wide, 90 degree bevel, similar as your 40 or 60 degree secondary edge. It is put on a main primary chisel edge.OK. Let's think about this. The blades get dull when they get too rounded over, right? The edges/corners on your flat edged blade are starting out at
an included angle of around 130 degrees!
That is obvious. You probably also know a lot more about lawn mowers than me. I don’t even know how they sharpen their lawn mowers in South America or in your area. However, up here in WI I have only seen chisel ground edges on lawn mower blades and never have seen even a 90-10 V ground edge. Yes, my 90 degree flat edge bevel is on a chisel ground edge. I really don’t know why but I can make a guess as to why the cutting edge is kept down on the low side of the blade. Guess 1 is it probably helps with airflow pulling up the grass blade to be cut. Guess 2 is to keep drag/friction on the blade to a minimum. If this will make a difference in cut quality from a blade with a 90-10, 30-70, or a 50-50 v ground edge I don’t have any idea. I am just assuming the manufactures are all keeping the edge on the bottom for a reason. I’ve never seen nor used a lawn mower with any type of V edge on it. I do know you will get a better cut depending on design, if your mower deck has a 1/8 to ¼ inch forward slant. Meaning when the blade tip is forward it measures say 3 inches off the ground, and after it spins and faces the back it is 3 1/8 to 3 ¼ off the ground. But what ever works, right? What type of grass? How sandy and rocky is your soil? How fast do you cut and how long is your grass? What type of mower do you use? All have a lot to do with how your lawnmower cuts.I don't care how some manufacturer sharpens their blades. Knife manufacturers can't even get edge geometry right!
Ok I think I see where your confused. The cutting edge isn’t the corner between the 90 degree flat and the primary grind your thinking of a v grind with one side at 90 and the other side of the edge at 40. That’s not correct. The cutting edge is at the bottom of the 90 degree bevel. Think of a chisel with one side of the cutting edge at 0 degrees and the other side with your 40 degree primary and a small secondary at 90. Now is having that secondary at 90 better worse, the same as having it at 60 degrees? I don’t know but touching up the 90 degree flat is easy and quick to do, and I get much less chipping than I did without it.OK. Let's think about this. The blades get dull when they get too rounded over, right? The edges/corners on your flat edged blade are starting out at an
included angle of around 130 degrees! (on the top side; the bottom corner should be closer to 90 degrees.) It only takes a tiny bit of wear before it's
rounded to a 1/16" circle. Compare that to an edge that starts out at only 40 degrees, and
