- Dec 20, 2012
I ran a search and found plenty of threads questioning lawnmower blades before but not quite what I'm looking for.
There's plenty of advising against making knives out of these But I'm not looking to make a knife nor do I need A splendid heat treat, I'm just wanting to make simple machete, maybe use it as a cane knife?
The way I figure it should take a beating well and not need to be plenty hard, as long as you can put an edge on it, it should do.
I plan to anneal it, hammer it flat, bevel/grind it, heat it, quench it, throw it in the oven for (???) amount of time and quench it again.
So my question is not can you but have you had success making a "machete"-type knife and roughly what was your HT, roughly what amount of time should these temper for as that seems to be the big problem with these mystery steel blades.
What time/temp did you cook it for and is my plan about right as far as making something that cuts about right or is there some huge flaw in The process that I listed?
Thanks guys, 1st post over in this corner and 1st attempt at making something that cuts, take it easy on The new guy asking about how he should do all the things that he probably shouldn't do, I'm Gunna try it, might as well ask if anyone else has had luck before I just completely wing it.
