l will probably need to send to spyderco to get it fixed, can’t figure it out how soft plastic rolled LC200n?I sometimes use the shank of a 1/2” drill bit like a burnishing steel.
The way I picture your serrated blade, I suspect the lower 1/4 or 1/3 of the teeth are doing almost all the cutting. When you straighten the roll, it’ll weaken the bent part. You’ll probably end up removing the serrations and having a plain edge blade eventually.
Parker
Yes probably to much side load, I do cut lots of zip ties , weird ropes, and salt and Ivermec blocks in cardboard with plastic bands, even chest bones on deer and hogs , my moraknif serrated seems to hold up better with different serrationsI believe the black plastic you are referencing has a Shore A Hardness rating of 100, which is actually pretty high. Plastic zip-ties (similar hardness) are well known for rolling and/or chipping knife edges (via side-load stress during a cut). Spyderco serrated edges are typically relatively thin behind the edge, making that area more prone to damage from side loading.
My guess, the area of the edge that rolled had high side-load applied (in excess of the elastic modulus of the steel) during a cut resulting in rolled edge referenced in OP.
If you are interested in this side-loading issue as related to knife steel, suggest a review of link below (Edge Stability) for various explanations as to the how & why.
Edge Stability
Additionally, there is now a Part#2 at the bottom of the linked page above ;-)
EDIT:
Below, from a long trusted Spyderco forum member when it comes to corrosion resistant Spyderco steels.
Postby Surfingringo » Fri Jul 27, 2018 10:04 am
H1 vs. LC200n...Real World Observations![]()
Quote from Surfingringo
"It should also be noted that the weakest point of LC200n’s performance is actually the same as H1’s…a lack of strength. I have found that my lc200n edges will also roll under high pressure/hard media.
