LDC 109 Sebenza??
What is an LDC 109 Sebenza? Blade length, Blade steel material?:confused:
thanx in advance.
LDC is a line of limited knives from Les Robertson and Bob Neal from certain makers, there are only 50 of each knife that were made. 109 was the designation given to the ones Chris Reeve made. I think you can still read about them at www.robertsoncustomcutlery.com
The LDC-109 is a small CRK Sebenza. . .OAL 6.75”, blade length of 2.67”, and a closed length at 3.87".
If I'm not mistaken. . .the blade steel was ATS-34 (if not it was BG-42).
Of course. . .titanium scales. . .with 4 milled grooves on the face scale. The grooves ran parallel to the scale.
Beautiful little knife !
Prior to the -109. . .Les collab'd with CRK and out popped the LDC-9. Which was based on the large Sebenza.
thanks for the info guys. the things one needs to learn about with just one particular brand of knive.
cheers
The blades were BG-42 with a swedge, and there are two grooves on the lock scale as well.
With the standard Sebenza.
