- Oct 7, 2005
ok i'm just begining the jurney into knife making. ive been a welder since 1971 and have worked all sortsof steel an aloys of all types.
doing the best research i can this is what ive come up with.
i started with the bottom spring from a cj5 jeep.
using the tapered end so i wouldn't have as much grinding.
i cut it out way oversized with my o/a cutting torch so as not to decarbonise the steel i would be working with.
heated it to none magnetic and tapped it flat on the anvil. (read railroad iron here)and let it air cool.
reheated to nonemagnetic and let it air cool a second time.
im told you can repeat this a third time and oil quench, i didn't do this.
i have now ground and sanded to design.
and will heat rreat it this weekend.
im told all that needs to be done is a one hour soak at 400 degrees. let it air cool and repete.
i will let you know on monday how this comes out. i have no way of testing on a rockwell scale , so i will give my best judgement using a file test.
if nothing else i have learned a lot about which tools i have that give the best results. i don't think i would sell any knives made this way, prefering to use a known quality if i were to be charging for them. but as a hobby made knife im happy so far.
P.S. that stuff sure polishes up nice on the sample i tried.
