- Jul 17, 2009
I just picked up a couple new Spydercos, one of which is a Leafstorm. There is an obvious coarseness when opening the knife. The action could be described as a grinding. I searched this forum and others described the opening action as very smooth. I wonder if there is a problem with the knife I have? The only point of contact is the ball on the lockbar. When I pull the lockbar away to close the knife, the blade swings freely and smoothly So, it seems that the ball on the lockbar (is it ceramic?) is causing the grinding. Is this a problem? I have several other Sypdercos, but none with the lockbar. My only comparison is a Sebenza, Mnandi, and Umnumzaan, and those are smooth.
Also, the lockbar engages poorly. When I open the knife, the bar engages slightly, then if I wiggle the blade or push the blade back (further in the opening direction) the bar will screech (there is a noise to it that I am trying to describe here) open a little farther. If I were to push the lockbar, after opening the knife, it makes the same noise and engages better.
The blade, as delivered, was loose, but that is easily remedied.
