- Jul 12, 2024
I made my first slip joint I noticed excessive rubbing on the tang to the liners I do not have a mill to make reliefs. Are washers a decent option?
I watched a video of this today. I think this would be my best option without a surface grinderDo you have a surface grinder? You will need to decrease the blade thickness to allow for the washers
I saw a maker who would grind the blade thickness down on both sides to where the mark would be but not the tang behind the mark where the pivot is. This allowed for no rubs on the makers mark.
Yes I agree until I get better I rather a softer liner like brass. I been following your tutorial from a couple years ago!You might just want to use the brass liners. They'll still rub, but it won't be as noticeable.
I thought about using a dremel also I need to restock my dremel attachmentsI've relived bronze liners with a cut of disk in a dremel and hid the toolmarks by texturing the whole liner.
