mate, like you I don't care for plastic. I'm also a lefty so
I have little choice but to make my own too.
Try this.....
Take a plain piece of paper and fold it over the knife carefully
pulling it snug to get the contours of blade and handle.
Draw a line around the outside edge while holding the paper
snug , take your time, to get the general shape and width.
While folded (remove from knife) in half cut the general out
line you made. This may take a couple of trims so be patient
and don't be afraid to start over.
Once the paper pattern is made to fit your knife make the belt
loop pattern to the carry hight you want and carefully tape to
try on your belt. You don 't want it to high or low. If you want
a dangler shelth that's easier to make.
Next transfer the pattern to the leather of your choice and cut
a thicker piece to run along the blade edge side of the sheath
about a 1/4" to 3/16 to act as a spacer to keep the blade from
cutting the stiches or fasteners you close the sheath with.
Then , if you don't / can't sew it vist the hardware store to
buy some rivets to close the sheath with and carefully
mark (with the knife in the sheath) the riviet spacing.
Don't go to high or you can't get the knife out. Go just
high enough to hold the handle very snug. Try to pull
out a couple of times to get that rivet just right.
Assemble the sheath putting the back loop in the pre marked
positon first then fold over and assemble the sheath without
forgetting the leather spacer piece between the sides at the blade
edge.
Soak in water when assembled, wrap knife in kitchen plasitic
wrap insert into sheath and let dry to form.
I've made several sheath this way and they all came out fine.
This simple fold over design works very well holding and
carrying my knive and I've yet to loose one.
Good luck mate.
