- Mar 22, 2016
What is the best best type of leather for a strop .thanks
If the strop is to be used with compound, it literally makes no difference as to the type of leather. In fact, the 'premium' horsehide strops are generally meant to be used bare, with no compound. All of the benefit of horsehide is forfeited, if it's covered with compound.
Used with compound, all that matters is that the strop material is smooth and/or uniform across it's surface, and holds the compound well. This means any other material, like fabric (denim, canvas, linen) or paper or wood, can work just as well, and even better in many circumstances. The biggest potential downside to any leather is it's inherent compressibility and/or softness, which can tend to round off the apex if not used with good technique (lightest pressure, conservatively low angle). Hard-backed strops of thinner fabric, and wood by itself, are much less compressible, and therefore will yield a crisper apex with a greater tolerance for somewhat heavier pressure.
David
How thick should the leather be
