Leather SwitchPlier holster?
Has anyone found a leather holster that works well with the SwitchPlier? The included nylon is very nice, but regs require that I can only use a leather one.
I have seen magazine holders used for more "rectangular" tools (Paratool, Leatherman, etc.), but the SwitchPlier is a bit "triangular", and the ones I have tried are either a bit too small, or large enough to allow the tool to slide around.
Our "large leather pouch" that is used for the PowerPlier is perfect. Either email or call (888.SOG.BEST) for more information.
Thanks! Does it fit "snugly" - i.e. not allowing the too to flop around?
Good. As long as I am going to place an order, I may as well combine a couple of items.
Can I place the medium sized slotted screwdriver tip in my SwitchPiler? I have the model with the Phillips and a nylon spacer. I would like to replace the spacer, and from the PowerLock picture, it appears that the medium slotted tip is "low and short". If not, what else will fill that gap?
The 1/4" drive gives the tool a lot of versatility (but takes up two component spots). When you call in, Loretta (in my Retail Department) can walk you through other options for your SwitchPlier.
