- Feb 19, 2021
Have another question regarding the newer version of the Ontario ASEK. I need a sheath for the one I have and the options I have available are 1) the old Ontario 499 leather sheath which I treated with a mixture of beeswax and neatsfoot oil. 2) the older Ontario SP2 leather/cordura sheath (I actually like those old Ontario sheaths). 3) I could purchase the SP24 sheath which is nylon, molle, with the plastic insert. I'm going to avoid kydex because I don't want to go custom and rather use what's available. I have heard people claim the plastic molded or "glass filled nylon" sheaths dull the blades like the Cold Steel Recon Scout sheaths and that is why they prefer leather. That treated 499 Pilot sheath I have does fit it very snug as I glued a piece of leather on the inside over the sharpening stone pouch rivet that was scratching my 499 Pilot blade years ago. Just curious which way others might lean towards. Leather (snug, absorbs some moisture if wet), leather/cordura (snug, also might absorb moisture) or nylon with plastic insert (little loose with some rattle but easy to dry if it gets wet).
