- Jun 2, 2001
Just got the new Leatherman Charge Ti. I am impressed with the new design. It is a beefier version of the Wave. It has Ti handles, tools that dont clump together, stronger pliers and a 154CM steel blade. All tools now lock open. It also has 2 bit holders that can be used with the supplied bits:
Phillips and flat tip eyeglass screwdriver
Phillips #1-2 and screwdriver 3/16"
Hex 5/32" and 9/64"
Hex 1/16" and .050
Hex 1/8" and 7/64"
Robertson #2 and #3
Hex 3/32" and 5/64"
Screwdriver 1/8" and Torx #15
(The bit selection is different for the Charge XTi)
Overall, I like the new package. Mine comes with a nylon sheath that can be worn horizontal as was as vertically.
Things that I dont like:
Even though it has Ti handles, it is heavier then my Leatherman Wave. I dont find that the handle design is anymore comfortable then the Wave's.
The bit holders only accepts proprietary Leatherman bits. It will not hold standard bits. This was something I didnt know before I purchased the unit. Leatherman only has the stock bits mention above. I called the company and a rep stated that they will be coming out with additional bits in September.
Recommendation:
If you already have a LM Wave and dont need a bit holder, I would pass on this model.
I will post more as I start to use the tool.
S.
Hex 5/32" and 9/64"
Hex 1/16" and .050
Hex 1/8" and 7/64"
Robertson #2 and #3
Hex 3/32" and 5/64"
Recommendation:
S.
