Leatherman Juice sheaths
Hello: Does anyone have a juice sheath from leatherman? The plastic one looks interesting but I am curious about how well the plastic sheath holds the Juice. Anyone have it? Any preferences; plastic or leather?
Any insight is appreciated.
Regards,
Doug
I use the sheath from a Gerber Compact Sport for my Juice CS4. Perfect fit.
A leather sheath came with the Juice Pro I got. Works well, I like the clip rather than the loop though it's not as secure. The sheath holds the Juice in both the closed position and open as pliers.
Phil
The Pro seems to be a collaboration between Leatherman and Costco. I've only seen it Costco and at no other site, not even Leatherman.com. It's basically a tweaked XE6 with the tweezers and some other extras. It is the most loaded Juice there is. And $59 and some change. Can't be beat.
Phil
You can use a standard size SAK leather sheath. Just stuff some paper into the bottom of the sheath so the Juice doesn't drop all the way into the sheath.
>"A leather sheath came with the Juice Pro I got. ... The sheath holds the Juice in both the closed position and open as pliers."
Anyone know if someone makes sheaths that hold the Wave in the open position as pliers? This would be perfect for fishermen.
I picked one up at my local costco today. Their stock
came in a few days ago. It was $59.00 and came with a
leather case. I have been carrying the wave which is a
little heavy, so am going to switch to the juice. I like
the blunt pliers and think I will use them more than the
needle nose.
