Leaving patina(rust on axe head) and no vinegar or sanding off axe head-NEED ADVICE!
What do you guys think of leaving a nice smooth patina(rust) coating on a nice vintage Plumb axe head that I just received from E Bay?
I have sharpened the head with my belt sander and it is extremely sharp. I have read that the patina protects the axe head from further rust. Any and all comments are welcome. I have restored over twenty one axes BUT never before left the patina and have used vinegar and judicious sanding and grinding.
Hope you guys respond quickly.
Ripshin Lumberjack
You can get rid of the bad rust while keeping the good patina, by using a wire brush cup on an angle grinder, as described below by Square_peg:
Steel or brass cup brushes on angle grinders both remove rust from an axe very well. Steel is faster. Brass is a little more gentle on the patina. If you use steel then get a knotted wire wheel not a crimped wire wheel. Crimped wire wheels throw wires much more easily. And never bear down hard on a wire wheel. That's a recipe for making wires go flying everywhere - your face, your chest, your neck....... Take it slow and let the wheel do its job.
When I want to clean the rust without doing any damage to the original finish or hard earned patina I will soak the subject in Ed's Red Bore Cleaner then scrub by hand with a bronze brush. But then I do a lot of work on old firearms where loss of patina equals loss of value.
Thanks guys! You know, for some odd reason I really, really like this old Plumb, I suppose, because it has taken a very nice blade contour and is just SO VERY SHARP!
I will be very careful and use your info to do more work on this old Plumb axe. For years I had one axe and did just fine with it. However, I had forgotten the satisfaction of restoring these vintage tools(21 restorations) and selling them to people who enjoyed using them.
Ripshin Lumberjack
