Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Oveready makes a 1600 lumen drop-in that uses 3 XPG-2 emitters. I'd say that beats it by a pretty wide marginYou can't beat a Malkoff.
Oveready makes a 1600 lumen drop-in that uses 3 XPG-2 emitters. I'd say that beats it by a pretty wide margin. Price is pretty hefty at $165. It can only run on rechargeables and not primary CR123s, so it would be about 15 minutes on high using 2 RCR123s. But it would be 15 minutes of glorious light:thumbup:.
Very much so, they're popular for good reason:thumbup:.Thanks for the suggestions. I guess I'll really have to give the Malkoff drop-ins some consideration.
Impress your friendsLOL...what am I going to do with 15 minutes of 1600 lumen light?
True, I found the low mode the be the most used on my triple LED module(when actually looking for something in the dark in the car). But to me, that's sort of the weak point of the Malkoff modules: the single mode. Unless you buy the Malkoff host with a high/low switch, you'll either need multiple flashlights or multiple modules to swap in and out of your flashlight depending on your needs. It's a solid and reliable module to be sure, but the lack of multiple modes is a little meh. Granted, the thing was designed with weapon use in mind, but I'm not sure many of us here have our flashlights mounted to our guns.High lumen count is cool and all but I like to use my light. I have several surefires and those that use light modules have Malkoff drop-in's installed. All are older (5+ years) yet still some of the brightest and best. They work every time, provide superior light output, and work with a wide range of battery configuration's. They are tough as nails too.
Favorite is a G2 with M60LL, great balance of light and runtime.
