Leek G10 Opening Issues
Hi all,
Just got a new G10 Leek. Overall, I like it. I actually like having the texture on the scales. Weight and balance are nice.
Mine has opening issues though. Already read a couple of the posts about torsion bar issues.
Symptoms:
(1) In order to open properly with the flipper, it seems that he pivot screw needs to be unusually loose. Even finger tight sometimes is too tight.
(2) Even when adjusted, sometimes I can only open 3 to 10 times before it doesn't flip well anymore. Note that the pivot screw doesn't seem to have loosened.
(3) Have noticed that the tip of the blade does not appear centered when it is a poor flipper. Sometimes if you wait a few minutes, it may recenter itself.
My attempts at fixing:
(1) Tried lubing pivot with teflon lube - no real difference, but shouldn't hurt.
(2) Ajusted pivot screw - only works for a little while.
(3) Disassembled and checked the torsion bar lube - ok
(4) Tried teflon lube for the torsion bar - no real change.
Other thoughts:
(1) Why did they use copper instead of teflon washers?
(2) Does anyone else think that the liner lock does not seem to "catch" enough of the blade?
Anyone have any other suggestions before trying to send it to Kershaw to have it looked at?
I hate to say it but it sounds like that one needs to go back to Kershaw for a little TLC. Also, the washers you speak of likely aren't copper. They should be phosphor-bronze and I think they are typically considered superior to synthetic washers.
:eek:...Hi smallcollector...I'm about as new to Keshaw as you are , but I found that with my G-10 Leek, there seems to be an actual tightening sequence you should use to get things put together well and have the ability to adjust the tightness of the pivot screw to get proper opening interferences. Get the handle screws in first but not too tight, then the pivot screw . Work towards the pivot from the furthest screw from the blade gradually til it's tightened at the handle yet free at the pivot...Then ya should have a workable adjustment left at the pivot screw...Good luck and let us all know if I'm hallucinating or not...:p
Seems like you've tried all you can. I'd send it to Kershaw
and let them have a go at it.
I have one and have never had an issue with it.
Also the liner locks up great on mine.
You may just have a bum torsion bar, call into our Warranty Dept., and request a few of them and see if that will fix your issue.
800-325-2891
also I have found that on the leeks if you back off the other three torx on the frame about a quarter turn , it makes a huge difference, if they are tight it puts to much pressure on the torsion bar cover.
Dave
All great suggestion above, and you could also try polishing the washers.
I place mine one at a time on a regular piece of printer paper with a dab of metal polish, and work it around in a small circular motion until it gets a nice mirror polish.
That sounds like a great idea for my Kershaw flippers. Thanks bro.:thumbup:
Hi,
Regarding the issue of the liner lock's interface with the blade I must say that I had the same concern when I obtained my Leek. After using it for about nine months now I can say I have total confidence in the design's ability to lock the blade in the opened position. It seems as the knife "wears in" their is a slight increase in the area of contact. I have found that washing the knife out thouroughly with dish detergent and not using any lube works best to maximize the knifes workings. Maybe the bronze? pivot washer is self lubricating. Anyways, I absoultely love my standard stainless Leek and consider it the best EDC I have ever carried. The ease of operation, the outstanding blade shape/grind, the ease of sharpening and reasonable cost all add up to a truly great everyday knife. If you cannot get your Leek to operate properly I recommend sending it back to Kershaw. They have a wonderful reputation for pleasing their customers.
John
It seems to be flipping fine, but I am still a little bit concerned that the pivot screw still seems so loose. I'm worried about losing the screw at some point, but I guess that can just be monitored.
I have tried the loosening the frame screws, but it is hard to tell if it is really helping or not.
Will probably try polishing the washers later.
I'll play with it more before considering sending it in though. Will keep updating as time goes on.
If you are going to go to the trouble of taking it apart to polish the washers , do as Thomas suggested, call and ask them to send some torsion bars and throw one in while you are at it. You'll be happy you did.
Dave
