I also think it depends on how a state defines a "switchblade" or "automatic knife".
For example: In NY state a "switchblade" is defined as Any knife that opens automatically by pressure being applied to a button switch or other device located inside the handle, or by the application of centrifugal force.
Now to open the Random Task pressure is being applied to the thumb stud, the thumbstud is not located "inside of the handle" The opening is also not completely "automatic" as there is manual movement of the blade before the torsion bar kicks in.
So it is legal because of a technicality.
Howeer, PA's definition of a switchblade is much broader and defines a switchblade as:
"any... dagger, knife, razor or cutting instrument, the blade of which is exposed in an automatic way by switch, push-button, spring mechanism, or otherwise."
notice the terms "automatic way" and "by switch, push-button, spring mechanism, or OTHERWISE."
The Random Tasks opening would qualify as an "automatic way" and the mechanism would qualify as "otherwise"
Below is the complete PA text taken from
www.knife-expert.com
read the last paragrah, it describes the term "otherwise" Making the Random Task illegal. (IMHO)
So you can see how it depends on how a state defines a switchblade. (the above is my opinion, do not take it as law)
Pennsylvania - Pa. C.S.A. 18.908. Prohibited offensive
weapons. (a) Offense defined.--A person commits a
misdemeanor of the first degree if, except as authorized by law, he makes, repairs, sells, or otherwise deals in, uses, or possesses any offensive weapon. (b) Exception.-- It is a defense under this section for the defendant to prove by a preponderance of evidence that he possessed of dealt with the weapon solely as a curio or in a dramatic
performance, or that he possessed it briefly in
consequence of having found it or taken it from an
aggressor, or under circumstances similarly negativing any intent or likelihood that the would be used unlawfully. (c) Definition.--As used in this section "offensive weapon" means... any... dagger, knife, razor or cutting instrument, the blade of which is exposed in an automatic way by switch, push-button, spring mechanism, or otherwise...
- also see 24 P.S. 13-1317.2. re: students bringing weapons on to school property.]
Pennsylvania case law:
Where opening knife required lock to be released, and once lock was released blade could be exposed by flip of wrist, knife did not have blade which could be "exposed in an automatic way"... by "otherwise" legislature referred to knives that were opened by some sort of mechanism which is not a "switch," "push-button," or "spring" mechanism but still a mechanism... (1979)
Louis Buccellato
http://www.themartialway.com
Knives, Weapons and equipment. Best prices anywhere.
"only the paranoid will survive"
