- Apr 20, 2001
I received the Camillus/Les Stroud SK Desert Folder today, some initial thoughts on it are good and bad.
Knife itself is OK, 440A liner lock with a very good no slip handle. Blade has some kind of "titanium non-stick" coating (more on that later) and came shaving sharp. Handle is good, very comfortable.
The liner lock is good, no play at all. Has nylon bushings, and at first was slow to open, but 1 drop of oil and it opens very easily now. The blade finish is very rough at this point, cosmetic though, doesn't seem to interfere with anything.
A small emergency firesteel locks into the handle, seems secure and would have been a nice idea if it worked..........
Here is the "bad" on this knife. The "titanium non-stick" coating on the blade, makes it (as least on mine) totally worthless to try to get any sparks from the firesteel. After nearly 30 minutes of scraping, I never got a single spark, and as you can see the blade coating barely has a mark on it. I did manage to get 2 sparks by scraping the firesteel with the pocket clip about 20 times, but none using the notch on the blade that is supposed to be used.
It's a $25.00 knife, so I wasn't expecting perfection, and the knife itself is OK, but the firesteel part just doesn't seem to work with whatever that blade coating it.
