Some issues to know abut with ebony:
1) IMHO, Cactus Juice isn't a good stabilizer for many things It can cause cracking.
2) Ebony does not like a sudden change in moisture content. It does not tolerate soaking it in anything. Even wiping the surface with alcohol or acetone too heavily can cause surface crazing.
3) Any heat will cause internal stress. If buffed hard, it will shine like glass, and then a day or two later it will be covered with spider web cracks.
4) Use on sharp tools and saw blades, and sharp fresh abrasives. Go slow in sawing and in sanding. If it builds up heat it will usually ruin the piece.
5) Ebony needs to dry for many years, even decades, to become stable. Most online ebony is far too fresh to use. It often ones covered in wax to "protect" it. When the wax is removed, cracks form soon due to the fact that the wood is still pretty green inside.
Ebony is more trouble that it is worth for many people. African blackwood is a more popular substitute.
When someone points out that ebony was used on folders, musical instruments, and other things for centuries I reply that is was properly cured and aged before those things were done. Also, that was ebony that had grown for as much as a century before harvest. Much modern ebony is farmed and forced to grow as fast as possible, then harvested at a much younger age than in the past.
