Lets see if the mythbusters will revisit the sword cuts sword episode
Your argument has no basis. Copper is vastly different from steel. Copper is soft and highly ductile. Sword steel is hard and brittle.
Anyway, they did test a real sword against a wall-hanger POS. Maybe a steel sword could cut an aluminum replica, but there's nothing legitimate or authentic about an aluminum sword.
They tested all crappy swords. Im talking about the difference between a high quality custom sword with differential tempering verses one of the POS flee market kind. They didn't cover all variables, which is essential for a legitimate scientific experiment.
Feel free to donate the swords you would like to see tested. Like you or me, they have limited budget. With literally hundreds of varieties and sub-varieties available, you need to be more specific on what they should have provided. I think they did a reasonably fair test, given the dubious premise of the original myth.
I suspect you didn't see the results you wanted. My understanding of the tests were whether they represented typical swords...and you're disputing the results because they didn't use atypical blades.
Let's say they did. What differences would you expect to see?
For that matter, please list all the variables they should have covered. Otherwise, this sounds like sour grapes, no?
Not all of the swords were crappy: one was a Bright Knight katana by Angel Sword corp. That's the one Kari referred to as the "modern high alloy", and the only one that did not break.
I wished I could follow this conversation. The link didn't pull up anything about swords. What is the myth?
Semper Fi!
They've tested a couple of sword myths, including the ability to catch a sword between your palms, and others.
The one in question was "An especially sharp sword is capable of cutting through another." They provided reinforcement through scenes of a couple Hollywood movies, in which one swordsman cleaves his blade through his opponents' blades, suffering no damage to his own blade.
The test basically consisted of construction of a simple arm-like apparatus that duplicated the mechanical swing of a human arm at the right angle, torque, and speed. The mounted a small variety of different types of blades (Eastern, Western, low end, higher end) in the mechanical hand, and then had them strike static swords (of equally various types), and filmed the results.
No sword was able to cleave through another sword; not surprisingly, both blades get damaged when there is blade on blade contact. Blades bent or even fractured from the impact.
Coldblooded357's critique is based on their selection of swords, in that they weren't of sufficient quality. However, the basic assumption of the myth is that a typical sword can cut another without damage. As such, their test incorporated much more than it needed to: the physics remains the same of clashing sharpened steel edges at strike velocities against sharpened steel edges: you damage both.
One thing I wish they would have done on myth busters was instead of cutting ballistic gelatin, they should have cut a hanging pig (similar size to a average sized man). Ballistic gelatin might be a good medium for shooting, but when cut, it looked to be very grabby on the surface of the sword. With a sharp sword and a good swing, you can sever a human sized pig in half, even through the shoulder and leg bones. meat cuts much differently than gelatin of the same density. The surface tension dynamics/friction are very different when you have wet bloody meat and bones.
I agree that they overuse ballistic gel; but you can mold lots and lots of it quickly and easily for multiple takes. Pigs are expensive, and what do you do with (literally) a ton of remains? They won't be fit for eating after spending hours under studio lights, whereas ballistic gel can be melted down and reused in some cases.
From what I understand, ballistics gel is kinda of expensive (maybe they get a great deal on bulk), and I think ballistics gel also gets rotten stinky when it gets hot.
They use pigs for a lot of other stuff, like leaving them in cars to rot in the sun, shooting them with canons etc.
