Lets Take a Trip to Arizona...(UPDATE)
Horsewright
Well, in a leather crafting way. As many folks around here know, we make a lot of chaps/leggings for cowboyin' use. Recently I had an order for a pair of Arizona Bells. These are a type of legging worn by cowboys and as the name suggests, originally from the AZ area. In recent years you have seen a widespread intermingling of different types of leggings from their regional homes. Colloquially, AZ Bells are know as "step ins", as the upper leg is laced together and the chap is pulled on. Some years back I wrote a little pictorial history of our making of all the different type of leggings. We use the term legging instead of chaps as there are so many different types. Ya can read here about the many different styles of leggings here:
Todays thread will be much more of a WIP so follow along as I build this set of AZ Bells. I've only built a few pair of these type of chaps so I have to go slow and kinda think about it as I go. This took a couple of days to get done but they were light days. A few hours here and a couple there. Here's our hides. Bells are traditionally made from a heavy 8/9 oz boarhide. This makes them extremely durable, kinda like a tank is durable but they are heavy. My customer and friend wanted a little lighter and a slimmer fit too, than is normal on these guys. We found these boarhides at Maverick Leather. They are 3/4 oz and oiled pretty heavily, just beautiful hides. Boarhide does come in hides BTW, not sides, as it's a smaller animal than a cow. We bought two hides for this project:
First part is to layout our pattern along the hide and get that situated right. You are trying to cut around any flaws or holes obviously and maximize the use of the good leather Here are our two pattern pieces. The chap leg itself out of brown paper and the leather strap is a hole punching template I made for the very first pair of bells I ever made:
The customer had driven over, (from the coast a three hour drive), for a fitting and this existing pattern I'd had from my friend Bear, fit him perfectly. So, we didn't have to make any size modifications, an unusual deal in the chap making business:
We need two upper leg reinforcement pieces. The one pictured has already been cut out and then flipped as its the the new pattern piece. These are cut out apart from the main leg piece and will be sewn on:
One leg and the two reinforcement pieces.
I use a roller knife to cut out most of the leg. However there is a small notch on the inside of the leg that I have to cut out with a roundknife:
Then this leg is flipped onto the other hide and used as the pattern for the second leg. I scribe around it with my red pokey tool and then cut out the second leg. ALWAYS remember to flip the first leg over before using it as a pattern. Ask me how I know:
This pair of chaps was going to have a contrasting dark brown fringe and accent pieces. So ya can see materials cost on a project like this can get up there, ya need two boarhides and side of dark brown chap leather. On this pair the fringe, bell reinforcements, lacing and pocket are going to be dark brown. Cutting out the fringe, pocket parts, and the bell reinforcements. Later we'll also cut two long 5/8" laces. The fringe:
All the dark brown parts except the laces:
This pair will have tooled yokes so we need to cut those out of 8/10 oz russet Wicket and Craig. I always use a straight edge when I can for cutting and the roller knife will cut this heavier leather too
Cut the curves with a roundknife:
Everything Is cut out so I'll tool the yokes now and get them finished up so they can be drying. This way when I'm ready for them they are good to go. Here they are tooled and oiled. After letting the oil set awhile they'll be finished and have their edges rubbed.
Meanwhile, I'll start putting the other pieces together. So the leg reinforcement pieces have to be skivved as they will go under the yokes:
They are then glued and sewn into position:
We are then going to glue up and sew our bell reinforcements:
So both reinforcement pieces are glued and sewn on both legs now:
So now the yokes, all finished, are ready to be sewn on. At the same time I will sew the two pocket pieces together. Bells generally have two pockets a welt pocket like this one on the right leg and a patch pocket on the left leg. However, on this order we were just doing the welt pocket on the left leg. The curve of the pocket allows the items carried to rest alongside the leg instead of on top of the leg:
Well time to go feed all the critters around this rancho. Check back tomorrow and we'll finish this WIP off. As always questions and comments are welcome.
Really nice write up !! Great pictures too !!!! :)
The round knife and the skiv knife , you had to show those lol. I’m thinking I’m going to be needing those !!! :)
By the way the round knife I have from you has been awesome !!!! Thank you
Great job, Dave! I have been aiming to get a round knife. I have never used one yet. Do you have an idea of when you will be making another batch of them?
I like that Shiv also. Mine is a cheap one from Tandy.
Thanks guys. I don't make roundknives any more. They kept trying to kill me when grinding. I occasionally still make a Push Skiver like that one. Its a great tool and we use it often. So much better than those razor blade skiver thingies.
Moving on. Our next step will be installing the pocket. Usually, its one of the last things I do but I'll always do it while the leg is still flat and since these lace together as one of the last steps I'll install the pocket now. Takes a little courage because you're gonna make a slit the entire width of the pocket in the chap leg for a welt pocket like this. I punch two holes and then scribe a line. Using my roundknife I cut along the line from the first hole and then after cutting about half way, I'll flip the leg around and cut from the other hole towards the previously made cut. Here in this pic I've flipped the leg around and am getting ready to cut from the second hole back towards the first.
Ya sew the top flap first and then the bottom one when sewing down the pocket flaps. Its important to remember to flip the pocket body out of the way on the bottom side when sewing the bottom one or you'll sew the pocket closed!
I have found over the years, its best to leave about an inch of the pocket body not sewn and you can see that here in this pic. If you sew all the way up there's a lot of stress put on those last few stitches from a hand reaching in and out and they tend to spread apart some. Leaving it this way makes a stronger pocket. Ya can also see if ya didn't flip the pocket up and out of the way here when sewing the bottom flap it'd be bad.
This order called for initials in the bottom of the bell. I have stack of a graph paper, plastic film that I use to make these kinds of patterns. My dad scored it for me years ago from a local print shop that was going out of business. These letters are 3" tall. Tricky cutting and tricky sewing.
This was done on both legs:
Closing in on getting these chaps done. In this style of chap if fringe is used, it is either cut out of the leg or laced in when the leg is laced together. Many Bells are made with out any fringe at all. Since we were using a contrasting color, we were gonna lace this fringe in. First let's get the fringe cut. I take my two fringe pieces and clip them together outside face in, or mirrored. Then using a straight edge and a roller knife, I cut the fringe. This pair has seven inch long fringe.
At first ya kind of worry it, but after doing a few dozen sets of fringe it goes pretty darn fast. These days maybe five minutes for me to cut that fringe. Mirroring the two pieces like this gives ya an exact piece either left or right, its not done just for time savings. I'll always finish off the end even though I know I won't use it..That would be the luck. The one time ya didn't, ya'd need it.
Then I glue the fringe down to the leg just to make the punching of the lace slots easier.
Using my hole template, I'll mark where the slots are gonna go. I have a 5/8" bag punch that about the only thing I use it for is laced up leggings.
The lacing I'll cut slightly proud of 5/8" so it fills the slot well. and then start lacing em together. The top of the lace has a slot cut in it and the lace is bled back on itself to hold everything together.
Only the thigh area is laced together but the lace continues on down past where the two parts are laced together as decoration and to hold the fringe in place.
On the left leg ya gotta remember to include a brass ring. This is always included on a pair of AZ Bells and helps hold the cowboy's tie ropes. They are slung from the middle of the string that holds the chaps together in the front and the passes through the brass ring. A tie rope is used to tie down cattle when working or doctoring them.
Well they're done Whadya think?
They will tie together in the front with a heavy leather string:
Course there is a belt in the back too but I forgot to take pics!
Thanks for watching and as always questions and comments are welcome.
G’day ,
Hope your cows are fat , your grass is long and your health is good .
How long in the leg are these ?
How much boot do they cover when your in the saddle ?
Howdy Ken
Cows look good, don't know how, as this is the second driest year on record. Grass is short or non existent, we never had green up, this year, on much of the ranch. Our health is good, thank-you my friend.
They touch the ground when walking and cover much of the boot when in the saddle. Watch this quick little vid. Pay particular attention to the ground crew and their leggings. Both are AZ Bells. Horseback is my son and daughter in law. My son, Logan, is riding my filly Lil Sis.
Also this one. Again watch the ground crew. Three sets of AZ Bells this time. Logan horseback again, this time on one of his horses, Spudnik.
Adam, the customer, will be coming over Saturday to pick up the leggings and I'll get some pics of him in em and on horseback too.
