cmd said:
I'm not sure how to spell it, but where is the line drawn between rust and patina?
One is destructive and one makes an old-world style protection, AFAIK.
Chris
Most metals are susceptible to oxidation, Aluminium and Titanium, for example are much more reactive than iron (and steel). What happens with them is that as soon as the metal surface is exposed to air (say if you scratch it), it oxidises, leaving a very thin oxide layer on the surface, and undergoing no further reaction. You can leave it in salt water all day long and nothing will happen.
In iron, the oxide, iron (II) oxide IIRC, has different properties. This is called rust and is the only compound to which the name applies. The oxide expands and lifts away from the surface, exposing fresh metal. This all happens locally, which is why you get pitting, rather than the entire surface turning red. What is more, the reaction is autocatalytic, meaning that the presence of iron oxide accelerates the reaction, this is why it is important to remove all signs of rust as early as possible.
Patina is where the surface has been oxidised by other means, and the resultant compound is not iron oxide, but "iron x,y,z", or it could be iron (III) oxide which has different properties to rust. I don't know much detail on this, but the principle is used for blueing steel, and you can DIY with a carbon steel knife. When you get a new blade, clean it and then cut lots of citrus fruits with it, then wash it. You should get a nice dull fairly even patina, that will provide a barrier to the attack of oxygen, thereby inhibiting rust.
Sound theory which I've never tried.
In a using knife, rust shouldn't be a problem as you are cleaning it and touching up the edge regularly, and it should build up a nice patina. For a safe queen, it shouldn't be a problem because you can leave it oiled (or otherwise protected) and unsheathed. If you keep a knife in your car or something, for emergencies, then you may want to condsider a stainless. Same goes if you're one of those people who likes to carry a dedicated SD blade that is never used for anything else (not a good idea IMHO).
