So i needed a head spinner to dome some pin heads for bone handles. So i ordered one from jantz knowing they didnt work well. Well, it didnt work at all! This is with 1/16 and 3/32 pins. I think i need to remove some of the meat around the wall so it doesnt get caught on the raised portions of the bone.
So i thought about i would ask if anyone else modified their head spinner and if it worked. So, have you? Tell me about it.
I then also made one out of a worn out dremel bit. I drilled a 1/8 hole in an inch thick piece of wood, stuck the bit in there, stuck my center punch in the other end and gave it a whack, then with the bit in a partially drilled hole used as a holder i drilled it with a 3/32 bit to carve out a little bit. Here is the result.
I then tried this spinner i made and it actually worked! The head isnt pretty, but the pin wont snag you as you run your finger across it.
I think if i cut a slot in it with a dremel it may cut a little better. I am just using some cutting lube and a lot of pressure with the drill press. I can probably sand the head by hand and get it to looking decent.
So, modify the jantz spinner or keep going with mine?
EDIT
I sanded it with 800 grit for about 5 minutes and it looks like this.
I should be able to get those black specks out in a few more minutes. I am so glad i bought an optivisor, you just cant see those specks without magnification.
EDIT
