I'm going to try to make some replacement scales for my Becker Campanion. Nothing wrong with the ones it came with, but maybe something thinner might work better for me. I see somebody sells 1/4" G-10 scales, but they cost more than I want to spend. Also, making new scales might be fun and shouldn't be too difficult to try.
I'm going to use 1/8" Lexan polycarbonate because: (a) I have some, (b) it seems like it might work. At first I thought 1/8" scales might be too thin but now it seems like a good thickness to try. And if 1/8" turns out to be too thin then I'll try 3/16" if I run across some small pieces somewhere around here. I've worked with Lexan a little and find it easy to cut and shape.
I considered trying acrylic first, instead of Lexan, but figured that while acrylic is harder, which is good in that it won't scratch as readily as Lexan, it also is more brittle than Lexan in my limited experience, thus being more prone to chipping and cracking. So I'll try Lexan first and see what happens.
One problem that might arise from using thin 1/8" scales could be the difficulty in attatching the scales to the handle with screws without having the screws protruding from the thin scales. I might have to use glue or epoxy, and that might be messy and unsightly. I'll see what works when I get there.
So that's my bright idea for the moment.
